Hello
Guest
it is
October 24, 2026, 09:44:24 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
Mach4 General Discussion
MACH4 Manual Screen
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: MACH4 Manual Screen (Read 7248 times)
Gerhard_68
22
MACH4 Manual Screen
on:
May 29, 2022, 04:30:35 PM »
Hi
I have installed the Manual Lathe Screen (Mach4_Manual_Lathe.m4prof).
If I switch from AUTO screen to Manual screen, there is always
the blue toolpath window overlayed as shown in attached pic
BR
Gerhard
Logged
frapo
11
Re: MACH4 Manual Screen
Reply #1 on:
July 13, 2022, 12:06:44 PM »
And how do you install this screen?
Logged
Gerhard_68
22
Reply #2 on:
July 13, 2022, 12:20:27 PM »
Hi
have problem solved
in toolpath config was a checkbox
„use frame“ or so
If I uncheck it, the toolpath in the manual screen was disappeared
BR
Gerhard
Logged
frapo
11
Reply #3 on:
July 13, 2022, 12:26:40 PM »
But how do install this screenset or screen,
Logged
joeaverage
7,663
Reply #4 on:
July 13, 2022, 05:47:13 PM »
Typically to change a screen set requires that Mach4 is running and with the <View> tab choose the <Load Screen> item and chose from the available screen sets. If you select a new screen set
when you shut down Mach your screen set preference will be updated courtesy of the ScreenUnLOad script.
Second way to do it is to create a new profile whereon you can select a particular screen set.
Logged
Print
Pages:
1
Go Up
« previous
next »
