Hello
Guest
it is
November 21, 2026, 01:49:49 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
New Mach3 install
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: New Mach3 install (Read 21068 times)
markn
29
New Mach3 install
on:
October 25, 2007, 08:12:58 PM »
Hello fellow Mach users,
I have recently upgraded win2000 to win2000 SP4, and now I don't see any outputs on the Diag. screen when I jog an axis. Is there a patch or plugin needed to fix this?
Chip
2,055
Gainesville Florida USA
Re: New Mach3 install
Reply #1 on:
October 26, 2007, 07:15:11 PM »
Hi, Markn
In your Mach3 folder you'll find a Driver Test Application, Click on it and let it run.
It will complete and close out, Then Re-Boot and run Mach3.
It's a Start, Chip
markn
29
Reply #2 on:
October 26, 2007, 08:00:50 PM »
Hi Chip,
I have run the driver test and it looked fine--just like the xample shown in the manual. I think I will next uninstall and reinstall mach3.
Chaoticone
5,624
Precision Chaos
Reply #3 on:
October 26, 2007, 09:43:08 PM »
Have you checked all of your settings? Did you save a copy of your XML?
If you could see the things I have in my head, you would be laughing too.
markn
29
Reply #4 on:
October 27, 2007, 01:01:06 PM »
Hi Brett,
Yes I cheched all the settings regarding the address of the Parallel port, how and why do I save a copy of the XML file? I don't have the PC hooked to anything yet, I am bench testing prior to hooking up the breakout board.
Mark
Carnoustie, Scotland
Reply #5 on:
October 27, 2007, 02:25:28 PM »
I am a bit confused as to what outputs you are not seeing when jogging?
To save your xml you just go to the mach folder and right click on the xml and copy then go to for example My Documents and right click and paste. The xml that you choose to copy will depend on which profile you are using, eg Mach3Mill.xml or Mach3Turn.xml or you may even have set up a customised profile, if so then it is that xml you want to copy.
markn
29
Reply #6 on:
October 27, 2007, 04:21:31 PM »
Hi Hood,
The outputs I am referring to are on the Diagnostics screen. When I jog an axis shouldn't the step and direction pin LEDs light up on the symbol that represents the Parallel port?
Mark
Reply #7 on:
October 27, 2007, 04:33:35 PM »
I dont know to be honest. On my computer here which is not hooked up to anything their state doesnt change but possibly if there is a breakout board etc connected it will.
Chip
2,055
Reply #8 on:
October 27, 2007, 05:44:55 PM »
Hi, Mark
The "Port 1 Pin's current State" don't flash, The "Blended Spd" , Current and Machine Coord should be moveing.
Check your Direction Pin's at Printer port for 0 or 5 volts depending on direction.
Thanks, Chip
markn
29
Reply #9 on:
October 27, 2007, 09:09:21 PM »
Hi Chip,
In fact I do see the cordinates change as well as the "Blended Speed", by the way what is the meaning of Blended Speed? What does it represent?
Thanks, Mark
Print
Pages:
1
2
Go Up
« previous
next »
