Hello Guest it is October 21, 2026, 12:53:55 AM
Author Topic: Steppers run one direction only for all Axis......  (Read 42819 times)
« on: January 27, 2022, 01:29:41 PM »
Hi! I,ve been working off and on with this for ~6 months. No success. Please see my system below.
Win 10, Mach3 (3 axis mill), ESS smoothstepper, C25S BOB (CNC4PC), HY DIV-268N 5A drivers. 4 wire NEMA 23 motors and 36V P.S.
The problem is with all axis. The on screen jog and Gcode entry do the same. Wiring has been debugged. driver tests show 5V one direction and 0V the other. Current draw is ~50ma one way and 0ma the other measured DIR+ to DIR-.
Uninstall and reinstalled Mach 3....no help.
I really need a solution.
Thanks......dt
Offline TPS
  •  2,627 2,627
Re: Steppers run one direction only for all Axis......
« Reply #1 on: January 28, 2022, 06:43:42 AM »
is your wiring simular to this:
https://www.cnc4pc.com/pub/media/productattachments/files/jinan2ess_1.pdf
some photos of your wiring would be helpful.
« Reply #2 on: January 28, 2022, 08:17:19 AM »
Yes. I ignored the AC side. I already found one error in it and suspect the rest.
Thanks.....dt
« Reply #3 on: January 28, 2022, 09:14:39 AM »
Hopefully I've done this right. please see the pic below.
Offline TPS
  •  2,627 2,627
« Reply #4 on: January 28, 2022, 11:49:41 AM »
wiring looks ok.
you have configured for Motor outputs X-Axis
step -> pin 2 port 1
dir -> pin 3 port 1 ?
can you measure  5V 0V at dir terminal on stepperdriver depending on direction?
« Reply #5 on: January 28, 2022, 12:02:05 PM »
yes to wiring. I can see the change from 5v to 0v between DIR+ and DIR- when changing direction. Also, the Y axis did reverse, but only twice and then not again.
Thanks.....dt
Offline TPS
  •  2,627 2,627
« Reply #6 on: January 28, 2022, 12:07:13 PM »
and you are 100% sure about the motor wires A+A- B+B- ?
« Reply #7 on: January 28, 2022, 01:21:08 PM »
No I'm not sure of the motor wiring. Do you have a suggestion for testing that?
Thanks.....dt
« Reply #8 on: January 28, 2022, 02:22:37 PM »
Searching more on the internet I found two references to motor wiring. So I swapped the B+ and B- wires on X axis. Now it runs reverse but won't run the other direction, only in reverse. The motor sounds better though.
 Also found reference to connect DIR+ to 5v rather than DIR- to common? Now I'm really confused!
Oh, and thanks for your help TPS.......dt
« Reply #9 on: January 28, 2022, 03:47:30 PM »
I have told you several times on the Warp9 forum to try swapping the Dir+ and Dir- wires....have you tried it?
