Hello
Guest
it is
October 20, 2026, 08:56:31 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Steppers run one direction only for all Axis......
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Steppers run one direction only for all Axis...... (Read 42811 times)
gldfshrdr
41
Re: Steppers run one direction only for all Axis......
Reply #10 on:
January 28, 2022, 04:19:46 PM »
Yes I did. It didn't fix the problem and the motors would not run.
thanks......dt
Logged
TPS
2,627
Reply #11 on:
January 29, 2022, 01:50:50 AM »
have you checke motor wires with ohmmeter
A+/A- and B+/B- should have the same resistance.
Logged
Print
Pages:
1
2
Go Up
« previous
next »
