Hello Guest it is October 21, 2026, 12:06:41 PM
Author Topic: Galil Spindle delay problem?  (Read 10303 times)
« on: October 18, 2007, 12:40:29 PM »
Hi Brian/Art,
When I toggle my spindle cw or ccw, if I have any dwell (been using 1 sec.) the toggle locks up, I can turn it off ounce but can not turn it back on.  MDI of M3, M4 works the same. The dwell light comes on and stays on.  If I have no dwell set, then the spindle toggles normally on and off as much as I like.  Can you please look into this and tell me if I have a setting wrong of if the Galil plugin or Mach has a bug?  Thanks,
Jim C.
Re: Galil Spindle delay problem?
« Reply #1 on: October 18, 2007, 01:08:36 PM »
Jimmy, I haven't had the opportunity to play with the Galil plug-in. How do you have your settings set in config, ports and pins, spindle? Can you post a screen shot of that for us?
« Reply #2 on: October 18, 2007, 03:06:07 PM »
Hi Brett,     I not sure how you do those fancey things like sending a screen shot,  if you can walk me through it, I would be glad to do so.  It seems to work fine in PP mode.  So I asume it is in the Galil plugin,  I believe you will need a Galil board installed to test it out.  I am using a DMC-2140 over ether net.  Thanks for the help, Jim
« Reply #3 on: October 18, 2007, 03:39:34 PM »
If it is doing fine on the PP and not the Galil, I suspect you are right. I have placed a screen shot to help explain a little. There may be some settings in the plug-in, not sure though. I have sent you a personal message.
