Mach Discussion => General Mach Discussion => Topic started by: JimmyC on October 18, 2007, 01:40:29 PM
Hi Brian/Art,
When I toggle my spindle cw or ccw, if I have any dwell (been using 1 sec.) the toggle locks up, I can turn it off ounce but can not turn it back on. MDI of M3, M4 works the same. The dwell light comes on and stays on. If I have no dwell set, then the spindle toggles normally on and off as much as I like. Can you please look into this and tell me if I have a setting wrong of if the Galil plugin or Mach has a bug? Thanks,
Jim C.
Jimmy, I haven't had the opportunity to play with the Galil plug-in. How do you have your settings set in config, ports and pins, spindle? Can you post a screen shot of that for us?
Hi Brett, I not sure how you do those fancey things like sending a screen shot, if you can walk me through it, I would be glad to do so. It seems to work fine in PP mode. So I asume it is in the Galil plugin, I believe you will need a Galil board installed to test it out. I am using a DMC-2140 over ether net. Thanks for the help, Jim
If it is doing fine on the PP and not the Galil, I suspect you are right. I have placed a screen shot to help explain a little. There may be some settings in the plug-in, not sure though. I have sent you a personal message.
