Hello Guest it is November 22, 2026, 10:35:15 AM
Author Topic: ......Unable to change active plane of movement, strange behaviour......  (Read 9866 times)
Offline Tarak
  •  229 229
I'm making a lathe screen and some of the program don't wok correctly unless I set active plane of movement to X-Z (in general config)
But when I restart Mach it resets it to X-Y?
Is this a glitch or is there something else I need to do.
I also haven't been able to set a toolpath display as a Turning control in screen 4, it always reverts back to normal, is this related somehow?
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: ......Unable to change active plane of movement, strange behaviour......
« Reply #1 on: October 17, 2007, 11:29:45 PM »
Hi, Darc
Did you start with a .Lset screen set, If not you'll need to rename it from .set to .Lset.
I use a program called XnVIew to rename them.
Hope this Helps, Chip
Offline Tarak
  •  229 229
« Reply #2 on: October 19, 2007, 01:26:53 AM »
Thanks Chip, I'll give that a go.
