Hello Guest it is November 13, 2026, 04:39:32 PM
Author Topic: Running three cnc machines from one pc.  (Read 23889 times)
« on: September 12, 2021, 08:38:04 AM »
Hi, most of you know that the most expensive thing apart from the machine is the stepper motor drives, power units, Bob etc. I have three cnc machines. A milling machine, a router and a lathe. I would like to run the all from the same Bob etc. Should say I don’t wish to run them at the same time. To keep things easy, is it possible to run more then one copy of Mach3 on a single pc. I can then just plug in the motor signal cables into the correct machine and run it. Anyone out there no the answer. Thanks.
  •  9,377 9,377
Re: Running three cnc machines from one pc.
« Reply #1 on: September 12, 2021, 09:12:41 AM »
You can run as many Mach3 Profiles from one PC as you wish.
« Reply #2 on: September 12, 2021, 12:19:31 PM »
Thanks. All good then
  •  9,377 9,377
« Reply #3 on: September 13, 2021, 05:20:25 AM »
All good  ;)
