Hello Guest it is November 29, 2026, 10:03:25 AM
Author Topic: Need info to run Mach3 with windows 10  (Read 32072 times)
« on: September 09, 2021, 06:51:59 AM »
what all do i need to run mach 3 on windows. I have a usb breakout board currently installed. do i need to install something else or do i need to replace it, please any info would greatly be appreciated.
  •  9,379 9,379
Re: Need info to run Mach3 with windows 10
« Reply #1 on: September 09, 2021, 08:23:23 AM »
What make and model is your USB breakout board ?
If you are not certain then please post an image of the board so that it can be identified.
« Reply #2 on: September 09, 2021, 10:19:09 AM »
ive attached a pic of what it looks like
« Reply #3 on: September 09, 2021, 10:28:44 AM »
This is the one i have installed.
Offline Filou
  •  59 59
« Reply #4 on: September 16, 2021, 02:40:30 AM »
Howdy,
perhaps this is what you have
https://www.joom.com/en/products/5bfbc1b428fc710101565b38
did the board come with a software driver ?
there is a need to tell Mach3 “where” to send the information it generates.
this job is done by a so called “driver” that needs to be installed.
I do not know more about your specific board, however. Good luck, Philippe
« Reply #5 on: December 04, 2023, 07:40:09 AM »
I am using the same board and a few minutes ago I downloaded the latest Mach3 and installed it.  The driver came with the board and connected OK so I started to configure Mach3.
Everything seemed to be working fine until I tried tuning the stepper motors.
After making a small change just to test, the program showed an error and then crashed out.
I tried several times and it happens each time.
I uninstalled Mach3 and reinstalled again, but the same happens as before.
I am not even able to test if the software will work for me or not, and the board I have bought is dedicated for Mach3 USB connection.
Any ideas what I could try to overcome this problem?
 The error message says art code error 9991
« Last Edit: December 04, 2023, 07:56:12 AM by regpye »
« Reply #6 on: December 04, 2023, 07:46:54 AM »
A driver should have been supplied with that board. The driver needs to be placed in the plugin folder.
The name of the driver is BL-UsbMach.dll
  •  9,379 9,379
« Reply #7 on: December 04, 2023, 11:53:44 AM »
As that board looks very much like the STB4100 you could try using the RnRMotion.dll
