Hello Guest it is October 21, 2026, 07:15:08 PM
Author Topic: Z axis not jogging or responding, x and Y are fine  (Read 19495 times)
« on: May 17, 2021, 04:20:28 PM »
Hi there, on a new install (last computer worked fine), the Z axis (up/down) will not respond at all. The numbers sometimes move, but the actual CNC does not. The X and Y axis are fine, respond to jog.
  •  9,374 9,374
Re: Z axis not jogging or responding, x and Y are fine
« Reply #1 on: May 18, 2021, 12:51:47 AM »
Check that you have the correct Port and Pin numbers (Step and Direction) for your Z axis in Config. / Ports & Pins / Motor Outputs and also check that it is enabled.
