Mach Discussion => General Mach Discussion => Topic started by: Dgillard on May 17, 2021, 05:20:28 PM
Hi there, on a new install (last computer worked fine), the Z axis (up/down) will not respond at all. The numbers sometimes move, but the actual CNC does not. The X and Y axis are fine, respond to jog.
Check that you have the correct Port and Pin numbers (Step and Direction) for your Z axis in Config. / Ports & Pins / Motor Outputs and also check that it is enabled.
