Hello
Guest
it is
October 21, 2026, 06:21:21 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Z axis not jogging or responding, x and Y are fine
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Z axis not jogging or responding, x and Y are fine (Read 19494 times)
Dgillard
1
on:
May 17, 2021, 04:20:28 PM »
Hi there, on a new install (last computer worked fine), the Z axis (up/down) will not respond at all. The numbers sometimes move, but the actual CNC does not. The X and Y axis are fine, respond to jog.
Logged
Tweakie.CNC
9,374
Super Kitty
Re: Z axis not jogging or responding, x and Y are fine
Reply #1 on:
May 18, 2021, 12:51:47 AM »
Check that you have the correct Port and Pin numbers (Step and Direction) for your Z axis in Config. / Ports & Pins / Motor Outputs and also check that it is enabled.
Logged
Print
Pages:
1
Go Up
« previous
next »
