Hello Guest it is November 13, 2026, 10:02:06 AM
Author Topic: 5 Axis Home Limit trigering simultaneously  (Read 16038 times)
« on: April 26, 2021, 05:01:29 AM »
Hello everyone,
I have a problem on my 5 axis CNC with B and C axis Home limits. All axis works fine, the machine is running normally.
The problem is when I press the B Home switch, both B and C are triggered simultaneously in Mach3. And the C switch does nothing.
I tried assigning the same switch to X, Y or Z and works fine. There must be some setting in Mach3 I'm missing.
I attached the video, you can see that I'm pressing the switch on input pin 4 assigned to Y Home and works normaly. Then I assign it to B Home it simultaneously triggers C Home as well.
Hope someone can help.
Thanks!
Offline TPS
  •  2,627 2,627
Re: 5 Axis Home Limit trigering simultaneously
« Reply #1 on: April 27, 2021, 04:43:27 AM »
maybe wron in this screenset, have you tryed with standard 1024 screenset?
