Hello Guest it is October 22, 2026, 06:38:16 AM
Author Topic: MPG issue  (Read 33806 times)
Offline comet
  •  338 338
MPG issue
« on: March 28, 2021, 08:36:57 AM »
I am trying to get the 1x 10x 100x to work with the velocity of of an MPG on a uc300
I have set in hot keys triggers 1 2 3
I have tried associating jog increment 191 192 193,  and also tried step value 265 266 267  and it makes no difference at the wheel
The port monitor is showing the pins are changing at the selection via a rotary switch on the pendant.
and the axis change rotary switch is working.
  Any Ideas??
Offline TPS
  •  2,627 2,627
Re: MPG issue
« Reply #1 on: March 29, 2021, 12:17:22 AM »
do a simple test first.
open VB Scriperwindow
Code: [Select]
  DoOEMButton(192)
  DoOEMButton(193)
  DoOEMButton(194)
open the Manual Tab
run through code with the >|| button and check for changing the step value
Offline comet
  •  338 338
Re: MPG issue
« Reply #2 on: March 29, 2021, 11:59:32 AM »
thanks for the reply,yes thats working
Offline TPS
  •  2,627 2,627
Re: MPG issue
« Reply #3 on: March 30, 2021, 12:20:57 AM »
ok then normaly it is enough to assign the oemtroggers to the right port and pin
and add in System hotkeys the oemcode (192...) to the oemtrigger.
i have seen in UC300 Manual that there is apossibilty to assign Inputs to functions,
but i do not have a uc300 so i am not able to say what can be assigned there.
Offline comet
  •  338 338
Re: MPG issue
« Reply #4 on: April 14, 2021, 06:24:18 AM »
Hi, I still dont have a resolution to this issue, I have put an enquiry on the cncdrive forum but no help.
Offline TPS
  •  2,627 2,627
Re: MPG issue
« Reply #5 on: April 14, 2021, 08:47:16 AM »
maybe in there is something to configure, but can not test, because i have no UC300
Re: MPG issue
« Reply #6 on: April 15, 2021, 01:55:04 AM »
Are you surprised?
CNCDrive is the manufacturer of the UC300 but also the software UCCNC, which is a competitor to Mach.
I can't imagine why anyone at CNCDrive could get too excited by trying to help you when they have others
to help whom use UCCNC software.
  •  9,374 9,374
Re: MPG issue
« Reply #7 on: April 15, 2021, 02:34:53 AM »
Stranger things do happen - CNC Drive staff spend a lot of time helping Mach3 users and providing support for their Mach3 plugin.
Offline comet
  •  338 338
Re: MPG issue
« Reply #8 on: April 23, 2021, 07:46:09 AM »
Are you surprised?
I wouldnt mind betting the majority of cncdrive users use mach.
Plus its the users that give you the suggestions on there forum rather than the company.
Re: MPG issue
« Reply #9 on: April 23, 2021, 03:09:08 PM »
Well, you might be right. I guess the 'proof is in the pudding'....to OP, 'have you had a response from the CNCDrive Forum?'
I have to compare this situation to the Warp9TD Forum, the manufacturer of the ESS, and there, Andy, the dedicated support employee
of Warp9TD answers all enquiries. Other forum members are invited to participate in the discourse but the site in principally a vehicle for
manufacturers support.
