Hello Guest it is November 24, 2026, 03:20:46 PM
Author Topic: OEMtrig  (Read 67066 times)
Offline TPS
  •  2,627 2,627
Re: OEMtrig
« Reply #10 on: February 21, 2021, 10:47:52 AM »
low or high active depends on how your Inputs are connected.
for are quick try you can assign port/pin pin to spare Input and check on diagnostic page
via led's for right Level.
Offline Holk
  •  16 16
Re: OEMtrig
« Reply #11 on: February 22, 2021, 08:56:32 AM »
So i have try it... and it give the msg on all of them, and when i push there come light in, but if i push oemtrig 1 the machine start, and it i after push oem3 to stop it nothing happen, but it i reset again and push oem3 them i light and stop activate, but i can only push one oem, and then it do not react
My idea
Make a file pr oem and in the Main file write a triggermacro Line with all the file names
Oemtriggermacro 334
Oemtriggermacro 335
Oemtriggermacro 336
As example ?
Or do you have an idea why its only read one oemtrig ?
Offline TPS
  •  2,627 2,627
Re: OEMtrig
« Reply #12 on: February 22, 2021, 09:17:23 AM »
in the sample code oemtrig2 is for stopping not oemtrig3
you can Setup only one triggerfile
pls post your m333.m1s and m334.m1s and a screenshot of your System hotkey Setup Screen.
« Last Edit: February 22, 2021, 09:19:17 AM by TPS »
Offline Holk
  •  16 16
Re: OEMtrig
« Reply #13 on: February 22, 2021, 12:27:47 PM »
i have call it 1919 and 1920 i should not make any difference
Offline Holk
  •  16 16
Re: OEMtrig
« Reply #14 on: February 22, 2021, 12:28:11 PM »
little more
Offline TPS
  •  2,627 2,627
Re: OEMtrig
« Reply #15 on: February 22, 2021, 01:30:05 PM »
have you tryed to disable achtive Low?
« Last Edit: February 22, 2021, 01:40:49 PM by TPS »
Offline Holk
  •  16 16
Re: OEMtrig
« Reply #16 on: February 22, 2021, 01:37:31 PM »
real i think... not from keyboard
Offline Holk
  •  16 16
Re: OEMtrig
« Reply #17 on: February 22, 2021, 01:37:53 PM »
from the box
Offline TPS
  •  2,627 2,627
Re: OEMtrig
« Reply #18 on: February 22, 2021, 01:41:46 PM »
Offline TPS
  •  2,627 2,627
Re: OEMtrig
« Reply #19 on: February 22, 2021, 01:44:54 PM »
this files are running, i have tested them.
