Hello Guest it is November 24, 2026, 03:20:40 PM
Author Topic: OEMtrig  (Read 67065 times)
Offline Holk
  •  16 16
OEMtrig
« on: February 21, 2021, 12:33:01 AM »
Hi...
I have a question.
I would like to have 5 buttons to work, and the first one i have set to OEMtrig#1000, set all in pin and ports... and it work, when i push it start the machine, but i would like it to turn on the led in the button when i push, and the 4 other should be turn off, so i have try to make a little script, but i this its here some is wrong
If isactive (oemtrig1) then
activatesignal(output2)
end if
And so on...
but the light do not turn on, the machine start when i push but no light, i have write in the file name in the ini string, so it should be loaded, and i have set it to load when " reset "
Any good ideas ?
Just to test i have change the activ low, just to see if they work, and all 5 buttons do work, so i think it the script or ?
Thank you in advance
Offline TPS
  •  2,627 2,627
Re: OEMtrig
« Reply #1 on: February 21, 2021, 03:04:52 AM »
you have to create two scripts.
first lets say it is M333.M1s
Code: [Select]
SetTRiggerMacro 334            'Set Macro M334 for OEM-Code 301
M333 Needs to be added to init string
the entire macro will be M334.M1S
Code: [Select]
If IsActive (OEMTRIG1) Then
End If
this will do the necessary code.
every OEMTRIG witch should call M334.M1s must be Setup with OEMCode 301 in System Hetkey Setup
Offline Holk
  •  16 16
Re: OEMtrig
« Reply #2 on: February 21, 2021, 04:02:41 AM »
Super answer...
i will try to make 2 files, but if all 5 OEMtrig should be set to 301, to read the script, then i would maybe tell in the script what OEM function i want ?
so it know that i want function 1000 on oemtrig 1 and it should turn on output 2 ?
So the first file M333 tell... when a oemtrig will be activatet, look in file 334 ?
Offline TPS
  •  2,627 2,627
Re: OEMtrig
« Reply #3 on: February 21, 2021, 04:27:11 AM »
exactly
so set OEMcode for OEMTRIG1 to 301 and the in the macroscript 304 :
Code: [Select]
  DoOEMButton(1000)
End If
thats the was it is.[/code]
Offline Holk
  •  16 16
Re: OEMtrig
« Reply #4 on: February 21, 2021, 04:46:38 AM »
Do you think it could look like this
( For start function )
  DoOEMButton(1000)
  deactivatesignal(output3)
  deactivatesignal(output4)
  deactivatesignal(output5)
  deactivatesignal(output6)
End If
( For stop function )
If IsActive (OEMTRIG2) Then
  DoOEMButton(1003)
  deactivatesignal(output2)
End If
and so on ?
Offline TPS
  •  2,627 2,627
Re: OEMtrig
« Reply #5 on: February 21, 2021, 05:11:23 AM »
yes thats it.
Offline Holk
  •  16 16
Re: OEMtrig
« Reply #6 on: February 21, 2021, 06:03:31 AM »
Now i have try and its almost work...
When i push it do the function, and there come light in, i have try with start, but it i then push stop nothing happen, but if i change oem code in the script so i start on another button then this work, its like it only read one button, and not read the rest
Offline Holk
  •  16 16
Re: OEMtrig
« Reply #7 on: February 21, 2021, 06:14:57 AM »
One more... when i push start it say in status Line... cannot reverse run from present feedhold 🤔
Offline TPS
  •  2,627 2,627
Re: OEMtrig
« Reply #8 on: February 21, 2021, 08:41:15 AM »
try to use this, only to see witch Trigger Comes up:
Code: [Select]
  MSGBox "Trigger 1 hit!"
  DoOEMButton(1000)
End If
  MSGBox "Trigger 2 hit!"
  DoOEMButton(1003)
End If
Offline Holk
  •  16 16
Re: OEMtrig
« Reply #9 on: February 21, 2021, 10:33:05 AM »
thanks i will try later today... do you know it oemtrig should have low activ or not ? and i guess output should be with out low activ
