Hello Guest it is October 25, 2026, 04:03:12 AM
Author Topic: How to Post processor for Turn-Mill Mach4  (Read 9861 times)
« on: February 07, 2021, 08:47:05 PM »
Hi
I have DIY CNC Lathe  now I use for lathe.
I use Fusion360 for post gcode.
and next step I want for create sub spindle and want to mill on C axis(on spindle) + X axis  but I don't know how to Post processor or setting .
I choice mach4 turning post processor on Fusion360  it's have error : Error: Milling toolpath is not supported by the post configuration.
how to creat for turn-mill for use X,Z+C axis ?
Asis
« Last Edit: February 07, 2021, 08:49:42 PM by abdulasis »
Re: How to Post processor for Turn-Mill Mach4
« Reply #1 on: February 08, 2021, 03:17:18 AM »
I don’t know about fusion but you can simply make the c axis an axis. We don’t know or care what your doing with the motors. The issue is we do not have the tools to make a Cartesian coordinate system from the c and x axis. We know how to do it we just have not done it because not enough people need it.
www.newfangledsolutions.com
www.machsupport.com
« Reply #2 on: February 08, 2021, 07:28:43 AM »
You may be able to get away with using one of the fanuc post processors to utilize the milling capabilities.
Chad Byrd
« Reply #3 on: February 08, 2021, 08:10:47 AM »
Hi Cbyrdtopper
I found post FANUC but have only A-axis.
Give some  advise me please for choice post processor.
Thank you.
« Last Edit: February 08, 2021, 08:13:09 AM by abdulasis »
« Reply #4 on: February 08, 2021, 08:13:33 AM »
I'm sad   :'( :'(
Thank you for answer, MR.Brian Barker
« Reply #5 on: February 08, 2021, 08:26:44 AM »
If you're using a lathe, try the fanuc turning.
Chad Byrd
