Mach Discussion => Mach4 General Discussion => Topic started by: abdulasis on February 07, 2021, 09:47:05 PM
Hi
I have DIY CNC Lathe now I use for lathe.
I use Fusion360 for post gcode.
and next step I want for create sub spindle and want to mill on C axis(on spindle) + X axis but I don't know how to Post processor or setting .
I choice mach4 turning post processor on Fusion360 it's have error : Error: Milling toolpath is not supported by the post configuration.
how to creat for turn-mill for use X,Z+C axis ?
Asis
I don’t know about fusion but you can simply make the c axis an axis. We don’t know or care what your doing with the motors. The issue is we do not have the tools to make a Cartesian coordinate system from the c and x axis. We know how to do it we just have not done it because not enough people need it.
You may be able to get away with using one of the fanuc post processors to utilize the milling capabilities.
Hi Cbyrdtopper
I found post FANUC but have only A-axis.
Give some advise me please for choice post processor.
Thank you.
I'm sad :'( :'(
Thank you for answer, MR.Brian Barker
If you're using a lathe, try the fanuc turning.
