Hello Guest it is October 21, 2026, 09:53:42 AM
Author Topic: E stop  (Read 8458 times)
Offline R A
  •  10 10
E stop
« on: February 06, 2021, 04:58:10 AM »
During the program I often get an e stop emergency. Sometimes none and sometimes several times in the same program. What could be the cause of this
  •  9,374 9,374
Re: E stop
« Reply #1 on: February 06, 2021, 06:04:54 AM »
This issue can be caused by electrical noise picked up on your inputs wiring (limit switches, estop, etc.). Do a forum search for electrical noise and you should find some info on; earthing, cable shielding, line filters, VFD noise, etc.
Offline R A
  •  10 10
Re: E stop
« Reply #2 on: February 06, 2021, 06:08:06 AM »
Thanks for the reply i wil change the kable from the E stop
  •  9,374 9,374
Re: E stop
« Reply #3 on: February 06, 2021, 06:36:13 AM »
Use good quality shielded cable with the shield connected to Earth at the controller end only.
