Mach Discussion => General Mach Discussion => Topic started by: R A on February 06, 2021, 05:58:10 AM
During the program I often get an e stop emergency. Sometimes none and sometimes several times in the same program. What could be the cause of this
This issue can be caused by electrical noise picked up on your inputs wiring (limit switches, estop, etc.). Do a forum search for electrical noise and you should find some info on; earthing, cable shielding, line filters, VFD noise, etc.
Thanks for the reply i wil change the kable from the E stop
Use good quality shielded cable with the shield connected to Earth at the controller end only.
