Hello Guest it is November 26, 2026, 11:51:28 AM
Author Topic: pcie to peripheral adaptor driver  (Read 12092 times)
Offline cruz
  •  19 19
« on: January 17, 2021, 01:47:54 PM »
i'm sure this is a issue more people have had.
i had to do a clean install of windows 7 (32bit) because of issue's with visual c++ file missing.
i then installed mach3 again.
before i did i took screenshots of the installed programs in control panel.
there were 2 PCI controllers installed
1: PCI multi-io controller
2: PCIe to peripheral adaptor
i'll add some pics of the screens and the hardware of the pc.
issue 1 (fixed): when i opend mach3 the screen flashed 2 times then a black screen and then windows restarted itself.
                       i then installed the PCI multi-io controller and this fixed that issue.
issue2: when i run the driver test from the mach3 folder i get the message "no driver sensed installed".
           if i look at my drivers i see a "mach3 pulseing engine" and under it "unknown device"
below it under other devices:
- PCI serial port
- PCI simple communications controller
both have a yellow exclamation mark
looking at any of the drivers properties, it says no driver installed.
the pc has a parallel port, and it used to run mach3 fine before the clean install.
here is a link to all the screenshots and pic they are too big to upload here.
https://mega.nz/folder/mGxm1JzI#6fcfNQ68ROnwt7b6IARJww
i'll try and upload some of them as reply
« Last Edit: January 17, 2021, 02:04:01 PM by cruz »
Offline cruz
  •  19 19
Re: pcie to peripheral adaptor driver
« Reply #1 on: January 17, 2021, 01:52:21 PM »
more pics
Offline cruz
  •  19 19
« Reply #2 on: January 17, 2021, 01:54:15 PM »
and more :)
Offline ZASto
  •  434 434
« Reply #3 on: January 17, 2021, 02:50:14 PM »
My personality is who I am.
Offline cruz
  •  19 19
« Reply #4 on: January 17, 2021, 03:54:50 PM »
You need a driver for your LPT board:
https://www.helpjet.net/Fs-50311538-16596496-31586755.html
how do know wich one to install?
where do i have to look?
Offline ZASto
  •  434 434
« Reply #5 on: January 17, 2021, 04:59:25 PM »
Download the .zip file, extract it to the convenient place, navigate to folder Wndows, then 32bit and execute Setup.exe
Offline cruz
  •  19 19
« Reply #6 on: January 17, 2021, 05:04:54 PM »
okay i'll try it tomorrow, and let you know how it went. thank you.
Offline cruz
  •  19 19
« Reply #7 on: January 18, 2021, 10:13:48 AM »
hi
The file you gave was already installed, it was the pci multi io controller.
On the screenshot of the old windows you can see I also had a PCIe to peripheral adaptor installed.
Maybe that is what I need, but I can find it online.
