Hello
Guest
it is
October 24, 2026, 11:03:58 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
Mach4 General Discussion
Using recent DEV Mach4 versions, I get this message
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Using recent DEV Mach4 versions, I get this message (Read 6693 times)
Mauri
328
on:
January 16, 2021, 02:37:07 PM »
Using recent DEV versions of Mach4 I get this message showing at the bottom "
Current Z Minimum to 0.0000 based on Parameter 1801
" when running some code in Sym.
What does this mean?
Mauri.
Brian Barker
3,860
Re: Using recent DEV Mach4 versions, I get this message
Reply #1 on:
January 17, 2021, 07:34:11 AM »
That is saying it will not go past 0.0 with the tool. This can be changed in the parameter file. The guys are working on building a release so I will send this to them.
Fixing problems one post at a time
www.newfangledsolutions.com
www.machsupport.com
Brian Barker
3,860
Reply #2 on:
January 17, 2021, 07:49:56 AM »
Looked and the newest versions this us all correct. By chance did you import a profile or bring in a parameter file? If this is all stock stuff, what profile did you use and what release.
www.machsupport.com
Print
Pages:
1
Go Up
« previous
next »
