Hello Guest it is November 19, 2026, 05:00:30 AM
Author Topic: G83 Peck drill does not drill to specified depth. Subsequent holes even less  (Read 20573 times)
I'm using Mach3, Gecko G540, on a Taig mill, drilling 5 holes using G83 as my material is quite soft and welds to the drill quite easily.  Hole depth is .75"  I set z0 with the drill bit about .005 above the work.  The first hole is about .6" deep and each successive hole is shallower by a significant amount.  Any suggestions would be appreciated.
Code is below
O1000
M03 S 5000
G90 G0 X0 Y0 Z.3
G1 X.93 Y.93 F15  (3/16 DRILL);
G1 Z.05 F5
G83 Z-.70 Q.25 R.1 F5
X.93 Y-.93
X-.93 Y-.93
X-.93 Y.93
G80 G0 Z.3
M6              (3/8 DRILL);
G0 Z.3
G1 X-.4 Y0 F15
G80 G0 Z.3
G0 X0 Y0
M30
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Slow the feed rate and see if you are loosing steps.
Try using the G73 drill cycle instead of the G83 to see if the problem goes away.
