Hello Guest it is November 20, 2026, 09:47:31 AM
Author Topic: Motor Tuning Small Arc's  (Read 10284 times)
Offline olf20
  •  325 325
« on: October 07, 2007, 05:56:38 PM »
Hi all!
I have been up and running on our Knee mill conversion for awhile now. I'm very please with what it can do. Right now we are running wood products via a router motor attached to  the Z spindle. We are using the latest version of Mach3 and VCarve Pro.
One thing I have noticed (and I know it has been discussed before) is that when the cutting requires a small arc / circle (3/4" to 1 1/2" dia) my Y axis seems to chatter. I have tuned, retuned and retuned that axis but it still is there.
Is there something I can to to improve this? I have the basic knowledge on Gcode.
Thanks for any help!!!
olf20
Mach3, Atlas Knee Mill, 4th Axis, VcarvePro, ESS, Super PID.
Been Heating with corn since 1998
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: Motor Tuning Small Arc's
« Reply #1 on: October 07, 2007, 06:55:55 PM »
Hi, Olf20
Post your g-code, Is it Cad generated or Hand g-code ?
Post your XML file, It's in your C::\Mach3 folder, Probably Mach3Mill.xml, Make a Copy of it then Re-name the copy to off20test and  post it.
Are you running in Exact Stop or CV Mode ?
It's a Start, Chip
Offline olf20
  •  325 325
« Reply #2 on: October 13, 2007, 06:46:23 AM »
Thanks Chip for the reply. Sorry for the delay we've been farming.
Attached   Generated by PhotoVCarve
Will Follow!
CV Mode
