Hello
Guest
it is
September 08, 2026, 09:16:41 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
new computer, no movement
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: new computer, no movement (Read 21034 times)
guynamedbathgate
317
on:
October 06, 2007, 01:30:54 PM »
just swapped out an old computor for a not as old computer on my machine. everything is set up the same but I have no movement. whats the first thing I should check. paralel port voltage???. how do I check that? can I get a reading off of my hobbycnc board somewhere to see if the voltage is too low?
Chris
Carnoustie, Scotland
Re: new computer, no movement
Reply #1 on:
October 06, 2007, 02:25:41 PM »
I presume you have checked and set the correct address of the parallel port? To check the voltage just put a voltmeter between a Direction pin and a ground on the disconnected parallel port cable and see what the voltage is, it should be 0 one way and near to 5V the other.
guynamedbathgate
317
Reply #2 on:
October 06, 2007, 03:10:04 PM »
hmm Im getting about 4.26 volts at the direction pin. but It is not droping to zero when I jog back and forth. Im not sure mach is comunicating with my printer port. I checked the port adress and it appears to be correct. so what do I do next
Reply #3 on:
October 06, 2007, 03:11:44 PM »
post your xml and I will test it out on my home computer.
Chip
2,055
Gainesville Florida USA
Reply #4 on:
October 06, 2007, 03:21:35 PM »
Hi, Chris
On Mach startup in the Status window are you seeing Driver Successfully Initialized.
Have you run the driver test ?, It's in your C:\Mach folder.
Hope this Helps, Chip
guynamedbathgate
317
Reply #5 on:
October 06, 2007, 03:23:44 PM »
here is my xml. will run the driver test again.
guynamedbathgate
317
Reply #6 on:
October 06, 2007, 03:32:22 PM »
huh? wierdest thing. I had installed an older version of mach this morning because I was having issues with they newer version. anyhow long story short. I clicked the driver test shortcut and instead of getting the driver test screen I got a window that said "Driver now installed, Please reboot your system" so I did. and we're moving again. thanks guys.
Reply #7 on:
October 06, 2007, 03:39:45 PM »
Great news, I have been searching the room for a cable so I could test things out, couldnt find one as I have butchered them all up for the I/O cables on my servo drives.
guynamedbathgate
317
Reply #8 on:
October 06, 2007, 03:58:10 PM »
well the effort was much appreciated.
Reply #9 on:
October 06, 2007, 04:12:49 PM »
Ha ha, no problem, I am sure you would do the same for me. In fact you may be able to help me out if you have been using Turn for a while. I am in the closing stages of my Lathe retrofit and have been setting up the tooltable today but wasnt sure about the Tip Direction entry. You got any idea or should I just resort to experimenting
I am thinking at the moment for instance if I have a PCNLL tool in I would put the tip direction as 95degrees, but I was thinking it maybe should be 85 degrees. Any idea?
Print
Pages:
1
2
Go Up
« previous
next »
