Hello Guest it is October 24, 2026, 12:44:11 PM
Author Topic: G31 Probe  (Read 32939 times)
G31 Probe
« on: September 06, 2020, 04:01:13 PM »
Need help.
Mach3 Version  3.043.062
CSMIO/IP-S
DMM DYN2 Servo
Machine runs fine and has for years. Wanted to do some Straight Probe to measure.
The G Code
G1G31Z-3.2F25.
G1G91Z.1F25.
G1G90G31Z-3.2F5.
G1G90Z0F50.
M30
In Single Block it feeds down in Z in first block until it trips Probe Switch.
Z Stops and displays Probe Hit OK
I hit Start and I get an e-Pid error.
Sometimes no movement at all and sometimes the Z will jerk up and fault.
With version 3.043.062 the Run LED stays on always.
So I switch to Version 3.043.044 That version is recommended by CS Labs for use with the CSMIO/IP-S
Got it all set up and running using same settings.
Loaded the above program, turned on single block just to make sure all my setting are good. Hit Start and executed
Each line one at a time and all worked. I’m happy thinking I got this. Turn single block off and hit Start.
Z moves until Probe switch is hit and e-Pid fault again.
The only difference I can see between Mach3 V .044 and .062 is in .044 the Run LED turns off when stepping through the program in single block.
So I started the machine back up using Mach3 V .062 and it faults in single block unlike V .044
Any ideas would be much appreciated.
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: G31 Probe
« Reply #1 on: September 06, 2020, 07:43:36 PM »
Try taking the G1 out of the G31 lines, G31 is a feed command and may not like the G1 on the line
Re: G31 Probe
« Reply #2 on: September 16, 2020, 01:44:09 PM »
It was suggested by CS Labs to use Mach3 version .022 - .044 and to put the G Code into VB Script. I wrote an M code as follows.
Code”G31G90Z-2.8F25.”
While(IsMoving)
Wend
Code”G1G91Z.1F50.”
While(IsMoving)
Wend
While(IsMoving)
Wend
Code”G0G90Z0”
While(IsMoving)
Wend
It worked perfectly. My only complaint would be Single block doesn’t work in an M Code so it executed the whole script without stopping.
Offline TPS
  •  2,627 2,627
Re: G31 Probe
« Reply #3 on: September 16, 2020, 02:56:04 PM »
Single block in macros is not working!
BTW: the code is redicoulous anyway.
