Hello Guest it is October 24, 2026, 10:34:19 PM
Author Topic: OEM trigger??  (Read 13202 times)
OEM trigger??
« on: October 02, 2007, 07:20:30 AM »
hello
using Mach 3 to induction harden pins for Ford,, and it works awsome!!  I have setup external start, stop button using oem triggers.  the problem is when I press the stop button It stops the g code but leaves whatever outputs that have been turned on,, on,, I have looked through the oem tigger names and cant seem to find one that will shut all outputs off.
Thank
Josh
Offline GaryB
  •  108 108
Re: OEM trigger??
« Reply #1 on: October 02, 2007, 10:15:16 AM »
General config, check "turn off outputs" under pgm end section
Beckwith Decor Products
ArtCam Trainer
Onsrud & Custom CNC tooling Distributor
Wichita/Derby Kansas
http://www.beckwithdecor.com
Re: OEM trigger??
« Reply #2 on: October 02, 2007, 11:56:44 AM »
I have that set already,  thats for your M30 command.
thanks for the reply
Re: OEM trigger??
« Reply #3 on: October 04, 2007, 01:56:42 PM »
Have a look at the Brain, shouldnt be too hard to reset the outputs to what you want.
Re: OEM trigger??
« Reply #4 on: October 09, 2007, 08:28:04 PM »
Hello Josh Learman,
I am an automotive induction heat treater also, close to Detroit.  I have built a scanner and "lift and rotate" and  several drop fixtures with PLC's but I never considered using Mach 3 as a control, it could save a lot of money and standardize all my interfaces  I just completed a three axis engraver (A personal project) but still trying to stop occasional "External Emergency Stop Requested" messages.
Induction noises from the stepper motors I suppose.  But that is nothing compared to High Frequency Induction noises.
I would be interested in how you control your logic signals around all that noise.
bill at wulkaninduction dot com
