Hello Guest it is October 22, 2026, 07:43:08 PM
Author Topic: Touch sensor mounted at side of spindle.  (Read 5681 times)
« on: August 19, 2020, 12:11:07 PM »
Hello,
is it possible to setup somewhere in Mach4 offets of touch sensor? I decided to mount my self made sensor not in spindle but at some offset (to have quick access to measure without changing tool). So what I want is to perform some calculation in TouchOf plugin to substract offsets.
Best regards C3l1n
Re: Touch sensor mounted at side of spindle.
« Reply #1 on: August 19, 2020, 05:38:55 PM »
why not? use G31 and cheack what ever you want ,just write the corect script
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #2 on: August 20, 2020, 06:09:13 PM »
you need to add code to the probing macros you are using allowing for the distance in x&y to the centre of the spindle
