Mach Discussion => Mach4 General Discussion => Topic started by: c3l1n on August 19, 2020, 01:11:07 PM
Hello,
is it possible to setup somewhere in Mach4 offets of touch sensor? I decided to mount my self made sensor not in spindle but at some offset (to have quick access to measure without changing tool). So what I want is to perform some calculation in TouchOf plugin to substract offsets.
Best regards C3l1n
why not? use G31 and cheack what ever you want ,just write the corect script
you need to add code to the probing macros you are using allowing for the distance in x&y to the centre of the spindle
