Hello Guest it is November 22, 2026, 09:27:33 AM
Author Topic: my cnc on mach3 homes to the positive  (Read 10265 times)
« on: August 18, 2020, 04:17:59 PM »
My cnc homes to the right, looking from the from of the table. To the positive.  I need to start on the left corner were it will be home 0 and from there I could move anywhere on the table and always have positive numbers. I reverse the motor wires, reverse the motors on pins  Wherever I make home on the 0.0 is on the left.
Is there a way to change the true homing on the left? Make that be the true 0.0 and everywhere you go on the table will always have Positive numbers.
I am talking about the short X axis across the front of the table.
« Last Edit: August 19, 2020, 12:38:09 AM by Tweakie.CNC »
Mtabernig
Offline TPS
  •  2,627 2,627
Re: my cnc on mach3 homes to the positive
« Reply #1 on: August 20, 2020, 08:42:10 AM »
Config -> Homing/Softlimits -> Home Neg
« Reply #2 on: August 22, 2020, 11:12:07 PM »
I think I did not explain myself properly.
When I home the machine, it will travel to the top right corner  anything from there down and left are all positive numbers.
fNow, if I go to config> stops/soft spots and check reverse direction box I can reverse and come to the left bottom corner,however, at that time any time I move the gantry  in any direction will change the numbers to an increasing negative.
I spend all day trying myself to and every time I try another change is not good.
If I move the X gantry to the right yea.. when moving left works but is on the wrong side. The Y is the one that the only way to change is to moved to the top of the table.
Please help    perhaps I can post some photos if is not explained right
« Last Edit: August 22, 2020, 11:14:28 PM by mtabernig »
Mtabernig
Offline TPS
  •  2,627 2,627
« Reply #3 on: August 23, 2020, 01:56:27 AM »
ok the you have to reverse axis direction.
Config -> Ports&Pins -> Motor Outputs -> Dir Lowactive
« Reply #4 on: August 23, 2020, 02:13:51 AM »
Thank you, I will try it tomorrow.
Mtabernig
« Reply #5 on: August 23, 2020, 08:07:10 PM »
Yes, it did work.
Thank you much.
Mtabernig
