Hello
Guest
it is
October 25, 2026, 03:17:06 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
Mach4 General Discussion
Stack lights LED Signal Tower
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Stack lights LED Signal Tower (Read 6423 times)
thebassbox
2
on:
August 06, 2020, 01:14:31 PM »
hi
i am searching for a script in mach4 for this Stack lights LED Signal Tower like this one in mach3:
https://en.cs-lab.eu/macro-for-a-signal-tower/
has anyone built something like this?
best regards
thebassbox
Logged
SwiftyJ
233
Re: Stack lights LED Signal Tower
Reply #1 on:
August 07, 2020, 08:35:39 AM »
This can be done by just mapping Mach4 outputs (Feed hold, G-Code Running, Machine Idle etc.) to the outputs of your controller to which the light is connected
To get a light to flash it would have to be done in the signal library using a wxTimer.
Logged
thebassbox
2
Reply #2 on:
August 07, 2020, 12:40:18 PM »
thank you
Feed hold and G-Code Running I can find, but Machine Idle is not in the Output settings
Logged
Print
Pages:
1
Go Up
« previous
next »
