Mach Discussion => Mach4 General Discussion => Topic started by: thebassbox on August 06, 2020, 02:14:31 PM
hi
i am searching for a script in mach4 for this Stack lights LED Signal Tower like this one in mach3:
https://en.cs-lab.eu/macro-for-a-signal-tower/
has anyone built something like this?
best regards
thebassbox
This can be done by just mapping Mach4 outputs (Feed hold, G-Code Running, Machine Idle etc.) to the outputs of your controller to which the light is connected
To get a light to flash it would have to be done in the signal library using a wxTimer.
thank you
Feed hold and G-Code Running I can find, but Machine Idle is not in the Output settings
