Hello Guest it is November 13, 2026, 03:48:23 PM
Author Topic: milling problem mach 3  (Read 7209 times)
« on: June 04, 2020, 07:49:14 PM »
hi, im starting with milling cnc, my issue is i create the cam on fusion 360 without problems and set the start point when im in the mach 3 i set the same offset as in fusion 360 but it doesnt work it always appear backwards and dont know why
Re: milling problem mach 3
« Reply #1 on: June 09, 2020, 12:40:40 PM »
more information and maybe some pictures are needed.
Is this a router or a mill?  My first guess is that you have one or more axis going backwards.
