Hello
Guest
it is
November 23, 2026, 04:10:55 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
milling problem mach 3
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: milling problem mach 3 (Read 7260 times)
fercho41890
3
on:
June 04, 2020, 07:49:14 PM »
hi, im starting with milling cnc, my issue is i create the cam on fusion 360 without problems and set the start point when im in the mach 3 i set the same offset as in fusion 360 but it doesnt work it always appear backwards and dont know why
Logged
fixittt
290
Re: milling problem mach 3
Reply #1 on:
June 09, 2020, 12:40:40 PM »
more information and maybe some pictures are needed.
Is this a router or a mill? My first guess is that you have one or more axis going backwards.
Logged
Print
Pages:
1
Go Up
« previous
next »
