Hello Guest it is November 23, 2026, 01:09:43 AM
Author Topic: Mach3 ATC screenset ER25 collet  (Read 9802 times)
« on: May 10, 2020, 12:20:20 AM »
Hi I am looking for a screenset for 8 tool change which uses air for mach3 on WIN7. regards Stuart
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Mach3 ATC screenset ER25 collet
« Reply #1 on: May 10, 2020, 08:01:29 AM »
Not enough information,  some pictures would help and a bit more info like do you have it tool changing now or are you wanting a M6Start.m1s macro to control your tool changer.
If yes we need to know Lathe, mill, router, something else, how it works, what outputs it uses, what inputs check what, then we may be able to help.
« Reply #2 on: May 10, 2020, 04:28:04 PM »
 Hi Graham
 M6Start.m1s macro is to control my tool changer. The 8 tool rack is setup along the Y axis, the spindle has a ER25 power draw bar. which is pneumatic. I am running mach3 on window7. regards Stuart
Offline TPS
  •  2,627 2,627
« Reply #3 on: May 11, 2020, 02:06:05 AM »
here:
https://www.machsupport.com/forum/index.php?topic=36417.msg249874#msg249874
i have posted some code witch might be a startpoint.
