Mach Discussion => General Mach Discussion => Topic started by: StuartW on May 10, 2020, 01:20:20 AM
Hi I am looking for a screenset for 8 tool change which uses air for mach3 on WIN7. regards Stuart
Not enough information, some pictures would help and a bit more info like do you have it tool changing now or are you wanting a M6Start.m1s macro to control your tool changer.
If yes we need to know Lathe, mill, router, something else, how it works, what outputs it uses, what inputs check what, then we may be able to help.
Hi Graham
M6Start.m1s macro is to control my tool changer. The 8 tool rack is setup along the Y axis, the spindle has a ER25 power draw bar. which is pneumatic. I am running mach3 on window7. regards Stuart
here:
https://www.machsupport.com/forum/index.php?topic=36417.msg249874#msg249874
i have posted some code witch might be a startpoint.
