Hello
Guest
it is
November 22, 2026, 03:54:40 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
OEM Code 352, 353, 354 and 355
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: OEM Code 352, 353, 354 and 355 (Read 17813 times)
Heli Guy
5
on:
September 24, 2007, 12:09:37 AM »
Hello All
Trying to use OEM codes 352 to 355 with no sucsess - most of the OEM codes work other then these 4. Has anyone tried them ?
Todd
Brian Barker
3,860
Re: OEM Code 352, 353, 354 and 355
Reply #1 on:
September 25, 2007, 07:55:36 AM »
Could you tell us a bit more about what you are trying to do??
Brian
Fixing problems one post at a time
www.newfangledsolutions.com
www.machsupport.com
Heli Guy
5
Reply #2 on:
September 25, 2007, 10:05:04 AM »
I am trying to run X and Z axis together and Y and A together.
Heli Guy
5
Reply #3 on:
September 25, 2007, 10:05:13 AM »
Brian Barker
3,860
Reply #4 on:
September 27, 2007, 08:55:47 AM »
Are you doing this with the P Port or an external device?
Can you just setup slaving under the slaving settings???
www.machsupport.com
Heli Guy
5
Reply #5 on:
September 27, 2007, 10:31:35 AM »
I am emulating a parallel port pins -
I tried to slave, but since I am using a 4 axis machine, I need to be able to slave but a few sec later to use it as a single axis
Also I can't find a way to slave Z to a and at the same time A to Y
Brian Barker
3,860
Reply #6 on:
October 04, 2007, 08:09:00 AM »
So you would like to change what axis is slaved on the fly??
Don't think we can do that
www.machsupport.com
Heli Guy
5
Reply #7 on:
October 04, 2007, 09:50:05 AM »
So what are the OEM codes 352 to 355 ?
Did anyone test them ?
I was able to get 352 to work, on the 2.X version but not on the 1.8X version
353, 354 and 355 didnt work on any version
Brian Barker
3,860
Reply #8 on:
October 07, 2007, 08:57:15 PM »
Could you please tell a bit more about what it is that you are trying to do???
A bit of code so we can see what you are up to would be a great help.
thanks
Brian
www.machsupport.com
Heli Guy
5
Reply #9 on:
October 10, 2007, 11:02:26 AM »
I am building a cnc foam cutter and need to move both axis with one key
The way it works now is that i need to hold two buttons on the keyboard in order to move two of the X axis for example.
I want to hold one button and move both X axis and hold down a different button and move them the other way
Same for the Y axis - want to move both Y axis by holding one button
I saw that the OEM codes 352 to 355 enable me to do so, but I can't get them to work
Thanks for your help
Print
Pages:
1
Go Up
« previous
next »
