Hello Guest it is November 23, 2026, 05:06:02 AM
Author Topic: New user. My Z needs to raise higher between passes. M3  (Read 17470 times)
« on: May 05, 2020, 07:59:30 PM »
Hello, and thanks for looking (and helping). I need my z to raise higher.Currently it raises about a 1/4" going from cut to cut (router) and I need it to raise, say, a half inch higher.  Also I have a ramping issue. When approaching start point from home, the router ramps down to position, I would like it not to, or have a shorter ramping distance.  In advance, thank you.
Re: New user. My Z needs to raise higher between passes. M3
« Reply #1 on: May 07, 2020, 03:26:29 PM »
You need to set safe-Z heights and ramping lengths in your CAD/CAM program.
Marsha
