Hello Guest it is October 20, 2026, 03:04:14 PM
Author Topic: Problem with Mach3 Image when loading up G code.  (Read 9215 times)
« on: May 02, 2020, 01:21:42 AM »
Hi All,
I'm new to the C'N'C and have a system that is using the Mach3 program.
I have a lot of G code programs  but every time i load it up the image in mach3 is off the table at the bottom and you can't see it.
Not sure what i have done or it's something to do with the coding. I have tired many different ones and the same result. Any help would be great.
My father In-law had it working great and it's been handed down to me as he has passed away and i didn't get enough time to learn how to use it before hand.
If you can suggest any courses i could take to help me learn would be a plus.
Thanks again for any help.
Please see attached picture.
Cheers Gary.
Offline TPS
  •  2,627 2,627
Re: Problem with Mach3 Image when loading up G code.
« Reply #1 on: May 02, 2020, 01:48:50 AM »
can you pls. post one of the gcode files?
« Reply #2 on: May 05, 2020, 11:02:12 PM »
ok i will try and post the G code if that helps
« Reply #3 on: May 05, 2020, 11:05:54 PM »
attached is one G code
Offline TPS
  •  2,627 2,627
« Reply #4 on: May 06, 2020, 02:43:42 AM »
it is working here
try to Change Display mode and the Regen Toolpath.
