Hello Guest it is November 13, 2026, 11:59:19 PM
Author Topic: What is disabled in the unregistered version ?  (Read 12608 times)
« on: September 23, 2007, 06:05:42 AM »
Just done a search couldn't find anything.
Phil_H
Offline jimpinder
  •  1,232 1,232
  • Wakefield, West Yorks, UK
Re: What is disabled in the unregistered version ?
« Reply #1 on: September 24, 2007, 06:47:12 AM »
Phil -
I am using the versi9on of Mach3 that is downloadable from the internet.
As far as I know, there is nothing disabled in the program itself, and it certainly all works fine on my set up (both lathe and mill)
The only thing I know that is limited is the number of lines of cade that can be used, and the downlaodable version is limited to 500 lines of code.
Lazy Cam and I suppose other add ons are limited
Jim
« Reply #2 on: September 24, 2007, 07:11:48 AM »
There are a few features that are diasbled. What in particular are you trying to do but can't?
« Reply #3 on: September 24, 2007, 07:40:09 AM »
Thanks for the answers.
It is not connected to my machine as yet.
I know i can't do run from here. But it seems when i run it it has slowed down the feed rates so it starts to run veryyy ssslllooooowwwwllllyyy
Another program i tried to run and of course it stopped at line 501 but i couldn't get it to run again i went to the beginning and pressed start it just went straight to line 501 and stopped.
I have now bought it so hopefully it will work correctly.
Phil_H
« Reply #4 on: September 24, 2007, 08:11:37 AM »
Good, if you have any more trouble, let us know.
