Hello Guest it is October 24, 2026, 02:38:03 AM
Author Topic: Regen Toolpath Hangs  (Read 20363 times)
Re: Regen Toolpath Hangs
« Reply #10 on: February 19, 2020, 08:29:52 AM »
Just curious MitchB, What program did you use to generate the .nc file. I use BobCad. v 28.
Pat
« Reply #11 on: February 19, 2020, 08:37:50 AM »
I think you should try this version :-
ftp://www.machsupport.com/Mach4/DevlopmentVersions/
Thanks for that suggestion.  As a test, I reinstalled 4300 after seeing that 3804 worked.  4300 still didn't work.  Then I tried version 4410 and that works fine.
« Reply #12 on: February 19, 2020, 08:38:56 AM »
Pat
I used MadCam from Rhino.
« Reply #13 on: February 19, 2020, 08:42:16 AM »
Since there is interest in the gcode, I've attached a file which causes the problem.
Offline jbuehn
  •  101 101
« Reply #14 on: February 19, 2020, 10:35:43 AM »
Looks like the M0 may be causing the issue and why it works in v4410
https://www.machsupport.com/forum/index.php?topic=42292.msg275421#msg275421
« Reply #15 on: February 19, 2020, 11:26:49 AM »
In version 4300, removing all the M codes made no difference.
