Hello Guest it is November 13, 2026, 04:34:41 PM
Author Topic: Regen Toolpath Hangs  (Read 20930 times)
« on: February 17, 2020, 01:41:55 PM »
I am using Mach4 Build 4300 on Win 7.  When I load or regenerate a toolpath, the progress bar progresses a little and then hangs.  This just started happening and nothing that I'm aware of has changed with my system.  This occurs with all .nc files including ones which have worked fine previously.
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Regen Toolpath Hangs
« Reply #1 on: February 18, 2020, 08:57:58 AM »
Are the gcode files very big
« Reply #2 on: February 18, 2020, 09:36:11 AM »
No.  Very small.
  •  2,785 2,785
« Reply #3 on: February 18, 2020, 10:01:34 AM »
Has the code any calls to special M codes?
« Reply #4 on: February 18, 2020, 11:39:23 AM »
I'm having the same problem. I've uninstalled Mach 4 ver 4300 and reinstalled several times. If I run a engraving code from the wizard the cnc will generate the toolpath and will engrave. I've tried several programs that I ran before I updated to ver 4300 and they don't work. I know have gone back to version 3804 and everything works properly. I contacted Machsupport about a week ago, which they wanted me to send a .nc file, I have. I haven't heard anything from them in almost a week. So I'm hoping that they reply to my last email in the future. I'll check back to this post to see if anything has been done to cure this problem instead of using an older version.
Pat
« Reply #5 on: February 18, 2020, 02:51:09 PM »
Thanks for that suggestion.  Going back to version 3804 fixed my problem as well.
« Reply #6 on: February 18, 2020, 03:54:43 PM »
mitch you didnt answer Garham
and as my experience with the jump between this 2 version in his question you have yours answer
the big different i had in that 2 version was in function in lua
new version can use same function name in 2 diferent M function
also each function cant see any other variables ,all variables act like privet for that function(i mean the function iside the M function)
so my sugest its first test yours M function  ,debug them and see if you can compile
work with old ver its can help you this time but its cant be answer for long time
they explain after that the reason its worked with old version was mistake
but this didnt help me ,because i had change all my function
« Reply #7 on: February 18, 2020, 04:28:36 PM »
Sorry for not replying to Graham.  The files I am trying are quite simple and small and have no special M codes.  They worked previously and I'm pretty sure they worked in version 4300 - so that is a bit mysterious.
« Reply #8 on: February 18, 2020, 04:56:54 PM »
you didnt write or modify any m function ?never in yours profile?
  •  2,785 2,785
« Reply #9 on: February 18, 2020, 05:39:00 PM »
I think you should try this version :-
ftp://www.machsupport.com/Mach4/DevlopmentVersions/
« Last Edit: February 18, 2020, 05:41:02 PM by Graham Waterworth »
