Hello Guest it is November 23, 2026, 08:51:28 PM
Author Topic: mach 4 testing limits and home switches inputs  (Read 6874 times)
« on: January 04, 2020, 08:31:47 PM »
hello
so im moving my machine from mach 3 to mach 4 its is a cnc router with a galil dmc 4080 controller and uses a gantry with dual motors i have limit switches at each end of the axis and proximity switches for the homes but i want to know is there some way i can test the limits and the homes like the diagnostic page we use to have in mach 3 were you could see what limits, homes, and other inputs were active?
thanks for your help
Re: mach 4 testing limits and home switches inputs
« Reply #1 on: January 04, 2020, 09:04:41 PM »
Mach4 has a similar page, just look two tabs to the right of Program Run on the second line of tabs on the main screen. It is labeled "Machine Diagnostics"
Steve Stallings
www.PMDX.com
« Reply #2 on: January 04, 2020, 09:21:28 PM »
thank you steve i turns out i had a different screen set on now i see the tab but again thank you very much time to setup these limits  ;D
