Hello Guest it is November 13, 2026, 09:24:27 PM
Author Topic: Mach 3 cuts all my DXF drawings 4 times  (Read 20453 times)
« on: December 06, 2019, 10:46:01 PM »
HELP  I can convert any file to DXF and with LAZY CAM conversion MACH 3 is happy. But when I use the program it cuts everything twice and then another twice a bit smaller. Any ideas would be appreciated
Regards
Helmut
  •  9,377 9,377
Re: Mach 3 cuts all my DXF drawings 4 times
« Reply #1 on: December 07, 2019, 12:55:51 AM »
Check your .dxf - chances are that you have double lines for each contour and LazyCam is just following the lines it has been given.
« Reply #2 on: December 07, 2019, 02:50:36 AM »
Your are right, when i magnify you can see it, do i have to delete every line i dint want?
  •  9,377 9,377
« Reply #3 on: December 07, 2019, 03:27:34 AM »
Ideally your .dxf should have been created with just one line (in the centre of the bitmap lines that were traced) but you have traced either side of the original lines.
The only solution with your existing .dxf is to delete the lines you do not want before creating the Gcode with LazyCam.
« Reply #4 on: December 07, 2019, 03:34:00 AM »
You pointed me in the right direction  a program called IMG2CAD cleaned it up once now they want $99  LOL Thanks
  •  9,377 9,377
« Reply #5 on: December 07, 2019, 03:59:18 AM »
$99  :'(
« Reply #6 on: January 02, 2020, 12:19:11 PM »
You really need to learn teh CAD side of CNC so you can clean up your own drawings before converting to Gcode. You time is free (;-).
« Reply #7 on: January 03, 2020, 06:19:35 AM »
There is a manual for LazyCam that I wrote and strongly suggest you read it.
Should be in Member's Doc's.
As Terry remarked, clean the file up before creating the DXF.
« Reply #8 on: December 02, 2020, 02:11:20 PM »
Yup this happened to me you probably had two lines in there and didn't see. When you set it to automatic then it will just cut twice and screw things up.
