Hello Guest it is November 21, 2026, 03:18:44 PM
Author Topic: Integra not responding to pings when on network  (Read 27959 times)
« on: October 15, 2019, 11:40:48 AM »
My CNC Windows 10 PC and Integra 7866 are connected to a simple 5 port Ethernet switch. I also have an Ethernet cable running to my network router. When I have the Windows PC DHCP connect to the WAN it receives an IP on the 192.168.1.x network with a default gateway of 192.168.1.1 (see screenshot). When this happens the Windows 10 PC can't ping the Integra.
When I set a Windows static IP of 192.168.0.10 the PC can ping and connect to the Integra (see screenshot).
The Integra's factory set IP is 192.168.0.99 (see screenshot).
If I update the Integra's IP address to 192.168.1.99 will that allow the Integra be seen on the network?
If not, what change can I make to the Integra's TCP/IP configuration to help it be seen on the network?
Ken
Re: Integra not responding to pings when on network
« Reply #1 on: October 15, 2019, 12:36:59 PM »
Yes.
« Reply #2 on: October 16, 2019, 09:21:40 AM »
Changing the IP address to 192.168.1.99 worked. My controller PC and network router can access the Integra.
Ken
