Hello Guest it is October 31, 2026, 12:56:07 PM
Author Topic: Mach3 DarkScreen Screenset - Now Available  (Read 674639 times)
Re: Mach3 DarkScreen Screenset - Now Available
« Reply #70 on: May 17, 2023, 11:06:04 AM »
Hello at all,
Thanks for sharing this great UI.
It's looking much better than the 1024 UI.
Question:
You spend so much time in building good looking Backgroud-Pictures.
But: How do I have to set up MACH3 that the Background-Picture is displayed without scaling?
I always get some bad looking . (I think it is form scaling the Background***.png Pictures)
« Reply #71 on: May 17, 2023, 12:26:14 PM »
Hi Kissling,
Sorry, I'm no longer working on that project. However, I will tell you that I had to rescale the backgrounds using Photoshop to natively fit my relatively low resolution Lenovo all-in-one PC on my mill. I used a combination of Photoshop, Illustrator and Machscreen to design/create/modify all of the other graphics in the UI.
I would try adjusting the UI in Machscreen since you can adjust the placement of the graphics/buttons/LEDs/DROs if necessary.
I hope that helps.
Good luck!
dotyman
« Reply #72 on: December 03, 2023, 03:59:13 AM »
Hello Dotyman, I really like your interface, but the "SHORTCUTS" don't work, right? I'm trying to load a new G-Code with "CTRL + L" and it doesn't work...
Greetings.
« Reply #73 on: December 03, 2023, 11:39:27 PM »
Hi JoeBar,
Shortcuts should work, just make sure you're on the appropriate screen/page. I just checked and the CTRL +L works to load a G-code file on my PC as long as I'm on the PROGRAM page in Mach.
Hope that helps!
Dotyman
« Reply #74 on: August 03, 2024, 09:43:55 PM »
Hi
Tried installing Dark Screen set on my Laptop OK, other Win 10 PC OK, the the Win10 pc that runs my CNC it will not load all the buttons etc on the screen
Any Ideas.
Ian R
« Reply #75 on: August 11, 2024, 03:09:30 PM »
Hi Ian,
Make sure you have all of the graphics files stored in the C:Mach3\Bitmaps\DarkScreenBitmaps folder.
Dotyman
« Reply #76 on: June 19, 2025, 06:39:14 AM »
Hi Folks,
I made some adaptations to the screenset to replaces macros that are missing.
https://www.machsupport.com/forum/index.php?topic=49298.msg302897#msg302897
« Reply #77 on: June 23, 2025, 11:01:03 AM »
What is the program you guys use to create screens for Mach3?
The Screen4 is a huge problem to work with... I have some customized old screens created by a old colleague and it's not easy to adjust it.
Offline TPS
  •  2,627 2,627
« Reply #78 on: June 24, 2025, 02:44:26 AM »
https://kd-dietz.com/pages/eng/machscreen/description.html
« Reply #79 on: July 09, 2025, 12:37:54 PM »
Hi @Dotyman and @graphicer82
Thanks for your sharing. Would you like to release a DarkScreen ScreenSet support 5 or 6 axis?
Thank you
