Hello Guest it is October 30, 2026, 08:07:26 AM
Author Topic: Mach3 DarkScreen Screenset - Now Available  (Read 631714 times)
Re: Mach3 DarkScreen Screenset - Now Available
« Reply #10 on: November 10, 2019, 09:19:55 PM »
Hello graphicer82. I installed the new screenset, and I still get a runaway on each axis if I jog with the keyboard. Does anyone else have this problem?
« Reply #11 on: November 11, 2019, 03:23:05 PM »
Hello Fusion. I don't fully understand the problem. Can you post the problem with a video
« Reply #12 on: November 11, 2019, 03:24:24 PM »
Thanks for sharing your latest version of this excellent Dark Screenset.
« Reply #13 on: November 11, 2019, 07:09:22 PM »
Hi graphicer,
Here is a video of my Mill with the normal mach3 screen.
https://youtu.be/Ke-tmPNNuRE
When I press the jog keys, it moves. When I release the key, it stops.
With DarkScreen, when I press the key it moves even after the key is released. It runs away.
It also switched axis of the keys.
Here is a video:
https://youtu.be/9loCFh_u8MA
Thanks for your help!
Mike
« Reply #14 on: November 11, 2019, 07:36:16 PM »
Thanks for video.
Very interesting. It works smoothly for me.
Please send your "System HotKeys Setup" window screenshot. On menu "Config/System Hotkeys"
And "General Logic Configuration" window on menu "Config/General Config"
« Reply #15 on: November 11, 2019, 08:01:03 PM »
Here are images of my config settings.
Thanks!
« Reply #16 on: November 11, 2019, 08:04:28 PM »
Hi Mike
I remove shortcut keys on screenset.
Please try this screenset file.
I hope system shortcuts work.
« Reply #17 on: November 11, 2019, 08:12:50 PM »
Hi graphicer,
I tried it. Now the jog keys do nothing.
Thanks!
Mike
« Reply #18 on: November 11, 2019, 09:05:30 PM »
Hi again..
I haven't quite solved the problem, but I found a workaround for you.
Screenset hotkeys and system hotkeys must be the same.
I have defined your system shortcut keys to the screenset.
Please try it again...
« Reply #19 on: November 11, 2019, 09:23:53 PM »
Thank you so much!!!!
It works great now!!
Mike
