Hello Guest it is October 24, 2026, 12:44:21 PM
Author Topic: CSMIO/IP-M and Mach3 Enable output issues  (Read 19041 times)
« on: October 08, 2019, 03:25:17 AM »
I'm trying to connect a Clearpath SDSK servo which requires a enable signal from Mach3 to energize it.
I have hooked up +24V to Pin9 and 0V to Pin22 (power for the outputs).
I'm using Output0 (Pin10) on the CSMIO and Port10 as the port.
I don't get any output signal. What am I missing?
Cheers,
« Last Edit: October 08, 2019, 03:27:07 AM by carlthomsen »
Re: CSMIO/IP-M and Mach3 Enable output issues
« Reply #1 on: October 08, 2019, 03:43:57 AM »
The Enable output in Mach3 lights up.
Offline TPS
  •  2,627 2,627
« Reply #2 on: October 31, 2019, 01:38:16 AM »
is the OUT0 led on the CSMIO-M comming ON?
Output assigned in Config->Ports&Pins->Output Signals?
if yes, assigned to what?
