Hello Guest it is October 25, 2026, 01:57:48 AM
Author Topic: Mach4 (4.2.0.4284) Feedrate ??? (wxLathe.set)  (Read 5780 times)
« on: August 12, 2019, 06:26:29 AM »
Any suggestion why the feedrate for ONE axis at rapid G0 would be higher than the maximum axis velocity set for the motors?
Both motors set at 1200 units / min
units set are mm in config.
MDI
Simple G0 X100 (or Y100) in the simulator
And the feedrate is listed as 1333.33
Rob
Albert Einstein ― “If you can't explain it to a six year old, you don't understand it yourself.”
Re: Mach4 (4.2.0.4284) Feedrate ??? (wxLathe.set)
« Reply #1 on: August 12, 2019, 08:25:14 AM »
Seems to work as intended / expected within 4.2.0.4162
G0 X100
Feedrate = 1200 units / min = Axis Maximum Velocity
Rob
