Mach Discussion => Mach4 General Discussion => Topic started by: robertspark on August 12, 2019, 07:26:29 AM
Any suggestion why the feedrate for ONE axis at rapid G0 would be higher than the maximum axis velocity set for the motors?
Both motors set at 1200 units / min
units set are mm in config.
MDI
Simple G0 X100 (or Y100) in the simulator
And the feedrate is listed as 1333.33
Seems to work as intended / expected within 4.2.0.4162
G0 X100
Feedrate = 1200 units / min = Axis Maximum Velocity
